1 - 1 of 1 Posts
From a press release issued by Yamaha Motor Corp. U.S.A.:
The 2009 Yamaha YZF-R1.
Cypress, Calif. – Forget everything you ever knew about the supersport liter class. Because once you hear the growl of the all-new 2009 YZF-R1, it will become clear that this bike is unlike anything before.
It’s all about power – delivery of power, to be exact. That’s because the all-new R1 is the world’s first production motorcycle with a crossplane crankshaft. Originally pioneered in MotoGP racing with the M1, crossplane technology puts each crank pin 90 degrees from the next, with an uneven firing interval of 270-180-90-180 degrees. The result is incredibly smooth, roll-on power delivery with outrageous amounts of torque for a rush like you’ve never experienced before.
The unique shape of the crossplane crank smoothes out fluctuations in inertial crankshaft torque to provide very linear power delivery as the engine’s combustion torque builds, giving the rider more linear throttle response with awesome power and traction exiting corners. Not just new, the R1’s new crossplane crank engine represents a complete paradigm shift.
To make the crossplane crank viable an advanced ECU individually maps each cylinder’s ignition and fuel injection timing. This powerful electronics package also controls Yamaha Chip Control Intake and Chip Control Throttle (YCC-I, YCC-T).
Also new for 2009 is the inclusion of D-MODE variable throttle control function that enables the rider to adjust performance characteristics to match a variety of riding conditions. In addition to standard mode mapped for optimum performance, the rider can select from A mode for sportier response in low to mid-speed range, and B mode for somewhat less sharp response for riding situations that require especially sensitive throttle operation. These 3 different maps at the push of a button allow the rider to choose the optimum power character for their riding situation.
This revolutionary new engine is housed in an equally advanced chassis. Control filled die-cast frame rails balance high vertical rigidity with relatively low lateral rigidity for increased high speed stability while improving handling, especially while leaned over during corner exit. A control filled die-cast magnesium sub frame cuts weight far from the center of balance and contributes to concentration of mass.
Visually the new R1 breaks new ground leading with twin projector beam headlights concentrated near newly placed forced air intake ducts. The sculpted body work features inner and outer shells controlling airflow around the bike at high speeds and forcing more cool air to the radiator and engine bay while eliminating the need for hot-air vents usually located at the sides of the radiator.
More than the just the next-generation of supersport; the 2009 YZF-R1 represents a major breakthrough in supersport technology and performance.
The new R1 will be available in dealerships nationwide beginning in January 2009 with a starting MSRP of $12,390. The 2009 R1 will be available in Raven/Candy Red, Pearl White/Rapid Red, Cadmium Yellow/Raven and Team Yamaha Blue/White.
Full information on all Yamaha models can be found at http://www.yamaha-motor.com.
1 - 1 of 1 Posts
