1 - 2 of 2 Posts
Just wondering if anyone else besides me has one and has done any mods to it? Almost done with the break-in and trying to get an idea of what others have done, difficulty involved, performance gains, etc.
i have the '01 but have scoped out the '04's quite a bit. i guess the first thing you could do is cut off that tractor mud flap in the back. all you need is a dremel with a cutting disc to make a clean cut. just take off your licence plate and follow the angles on the side and the line under the plate bracket. as far as gain for that.....it will make it look better. another would be to get a slip on can for it. it will make it sound a lot better and should boost performance a little. i personally like two brothers because of the sound. have heard many cans and i like mine the best. but you can look all over and find stuff like flush mounts and stuff like that. also get K&N air and oil filters. cost a little more but you get what you pay for. if i think of anything else ill let ya know.
also, hopefully you got your first oil change at around 500 miles or so. if not i would change it soon if you are almost done with your break in. IMO i would change it again after you have broken it in, just to make sure any little bits and pieces arent floating around. chances are they would get caught by the filter but its just my :2cents:
1 - 2 of 2 Posts
