What solvent to use to clean chain (gasoline)? - Sportbike Forum: Sportbike Motorcycle Forums
» Sponsors
» Insurance
Go Back   Sportbike Forum: Sportbike Motorcycle Forums > Sportbike Related > Technical Information
Thread Tools Display Modes
Old 10-22-2001, 02:48 AM   #1
SpeedRacerF4i
SpeedRacerF4i's Avatar
Question What solvent to use to clean chain (gasoline)?
Sorry for this common sense question, but I really needed to know.
I am cleaning and lubing my chain for the first time in my life! My manual says to clean the chain with a non-flamable, high-flash point solvent for cleaning the chain. I have read several time in this board that people are using kerosene to clean the chain. What I don't understand is that high-flash point solvent are in definition "flamable" right? If kerosene were safe to use on the chain, isn't gasoline just as good?
What solvents do you all use to clean your chain? I've heard people using automotive brake cleaner spray, carburator cleaner, kerosene, special $$$ cleaner sold in motorcycle dealers.....etc. Which is the best? Pros and cons given would be greatly appreciated.
BTW, I am using MAXIMAS spray chain lube. Anyone knows a better lube?
__________________
Rule in business "Buy what appreciates and rent what depreciates"
SpeedRacerF4i is offline   Reply With Quote
Old 10-22-2001, 02:54 AM   #2
Bonk!
Default
I use kerosene. Works great.
__________________
It turned out the kangaroo was right.
Bonk! is offline   Reply With Quote
Old 10-22-2001, 03:26 AM   #3
Pete
Guest
Posts: n/a
Default My Method
(If you do a search of the forums, you are sure to find this topic discussed at length.)
To clean my chain, after putting the bike on a rear stand, I soak a rag with WD40, and holding the rag tightly on the lower run of the chain, I spin the tire backwards. I keep doing this until I have all the gunk off the chain. LOTS OF PEOPLE will tell you that WD40 is not good for use on o-ring chains, because it can seep in past the o-rings and dissolve the packed grease. Whatever. When my chain needs replacing, I'll replace it. I'm not trying to make it last the life of the bike. Secondly, I'm not heavily spraying it on, so I don't think it's use is all that detrimental. I have seen o-ring chains cleaned and lubed with nothing but WD40 last for 15,000 or more miles. Use your own judgment.
To lube the chain, I use gear oil, applied in the same fashion as my cleaning method. I use a clean rag to remove the excess oil.
Old 10-22-2001, 03:36 AM   #4
chris_y2k_r1
Lifetime Premium
chris_y2k_r1's Avatar
Default Re: My Method
That's not how I heard you clean your chain
__________________
Fairing repair / Plastic Welding / Gas Tank Repair / Fabrication and Customization www.msrecycle.com or s3sportbikes.com
chris_y2k_r1 is offline   Reply With Quote
Old 10-22-2001, 04:01 AM   #5
Squidwannabe
Guest
Posts: n/a
Default
When I clean my chain I soak the chain in WD40 or kerosene. I like WD40 better because It's easy to apply. When I use kerosene, I use the toothbrush method. Takes a little longer but the outcome is better. Kerosene is also cheaper.
Again, I really soak the chain in whatever solvent I am using. It create a big mess but this is the way to get the chain clean. Old dirty lube is worse for you chain than no lube at all. (That's just my opinion, I have no scientific evidence to back it up )
When you lube you chain it's basically to inhibit corrosion and it does add a wear barrier. So you can use a lot if you want. Most will just fling off anyways. Just be sure to get the sides of your chain also.
Proper maintenance is key, use gear oil and keep your chain clean, lubed and adjusted.
Old 10-22-2001, 04:51 AM   #6
waverave r6
waverave r6's Avatar
Default
Kersone is what my manual recommends.
__________________
Rocket Scientist on R6
waverave r6 is offline   Reply With Quote
Old 10-22-2001, 05:53 AM   #7
SpeedRacerF4i
Default Gear oil as lubricant
Will gear oil fling and attract dirt like feces do to flies?
What about acetone as cleaner? I have a full can of it.
__________________
Old 10-22-2001, 07:15 AM   #8
Squidwannabe
Guest
Posts: n/a
Default Re: Gear oil as lubricant
If you use a lot, yes. As a rule of thumb clean your chain every 200miles.
Old 10-22-2001, 03:38 PM   #9
Stake
Moderator
Stake's Avatar
Default Re: What solvent to use to clean chain (gasoline)?
Just about everything has a flash point. The flash point refers to the temperature at which it will ignite. I made the mistake of using gasoline to burn some brush once, when I thought it was kerosene. THAT was interesting to say the least. So anyway, gasoline is probably just as good, but it is NOWHERE near as safe (it ignites nuch easier and much more violently than kerosene).
__________________
Don't try to keep up with my life, you'll only get hurt.
-Mike
Stake is offline   Reply With Quote
Old 10-22-2001, 10:18 PM   #10
maxw8s
maxw8s's Avatar
Don`t use Acetone.It will dry out your O rings.
maxw8s is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
Inactive Reminders By Mished.co.uk and FTP-Anime.com
