tire pressure; hot vs. cold - Sportbike Forum: Sportbike Motorcycle Forums
» Sponsors
» Insurance
Go Back   Sportbike Forum: Sportbike Motorcycle Forums > Sportbike Related > Technical Information
Thread Tools Display Modes
Old 07-16-2007, 12:57 PM   #1
iluvmacs
iluvmacs's Avatar
Default tire pressure; hot vs. cold
I just got off the bike after a quick 30 mile ride. I pumped the rear tire up to 40 this morning, and the front to 36.
I just checked the pressures and both were up 4 psi. Is this typical or is that pressure (due to heat from friction) indicative of a problem?
I've been having wear issues...
Thanks.
iluvmacs is offline   Reply With Quote
Old 07-16-2007, 01:46 PM   #2
Smitty
Default
Yes for I always set my air pressures a bit lower, in the start of the day, & in riding the tyre pressure will be up a bit, but okay for riding.
__________________
Remember all the others on the road are crazy & out to kill you.
Smitty is offline   Reply With Quote
Old 07-16-2007, 04:19 PM   #3
cookeetree
cookeetree's Avatar
Default Re: tire pressure; hot vs. cold
Quote:
Originally posted by iluvmacs
...I've been having wear issues...
How so?
__________________
In God, we trust; all others must provide data.
cookeetree is offline   Reply With Quote
Old 07-16-2007, 04:34 PM   #4
iluvmacs
iluvmacs's Avatar
Default
I got 3000 miles out of a set of Pirelli Diablos last year. The rear was worn to the cord in the center and the front sides were smooth.
This April I put on a set of Pirelli Diablo Stradas, which are supposed to last longer. I just bought a new set of tires today to replace the stradas, which exhibited the same wear pattern as the diablos, but at only 2000 miles.
Old 07-16-2007, 06:36 PM   #5
jakkyl
jakkyl's Avatar
Default
You're putting too much air in your tires, man. They're running only on the center because they are overinflated and that's the only thing touching the ground.
If they were wearing more on the outsides and not in the center, they would probably be under inflated, just gotta find the sweet spot.
It's normal for the pressure to increase once they're hot. A 4-5psi increase is about right. If I were you, I'd drop the front to about 32-33 and the rear to around 36. That'll put you at about the 36/40 you were going for to start with, once they're warm.
jakkyl is offline   Reply With Quote
Old 07-17-2007, 01:40 AM   #6
iluvmacs
iluvmacs's Avatar
Default
I was running at the MFG recommendation of 33/36. That was until I read that the lower pressure generates more heat due to larger contact patch. So, I pumped up the pressure to reduce the heat, and reduce the wear.
Thanks for the replies guys. Hopefully I'll figure this out. I can't be spending $200 on tires every few months.
Old 07-17-2007, 05:35 AM   #7
jakkyl
jakkyl's Avatar
Default
Well, those specs are for max load. It depends on how much you weigh and if you carry a passenger.
After your next ride, feel the tires. If they are pretty cool, drop the pressure. If they seem too hot, put some more air in.
Old 07-18-2007, 07:08 PM   #8
Whoaru99
Whoaru99's Avatar
Default
Most recommendations I've seen are to stay pretty close to the mfg recommended pressures - cold. Pressure rise from riding is factored into the cold pressures listed by the mfg.
Cold tire pressures are generally considered riding less than a mile (for a cage). I'd think it may be even less for a mc because of the generally smaller air volume in the tire.
Also, if the size of tire on the bike is not the same as original, the mfg original pressure specs no longer apply.
Have you double-checked your pressure gauge? Some of them are not very accurate and like other gauges, can get damaged, etc.
Whoaru99 is offline   Reply With Quote
Old 07-19-2007, 11:36 AM   #9
Smitty
Default
Whoaru99 has two good points. First being check your pressure gauge against that of several others. Personally I just use a cheap stick gauge, but have checked it against those more expensive ones in some of the shops.
Also if you read MOM then some of the info in there is way, way out of line such as the speeds of shifting & others. I look at the 40psi for my rear & have dropped it to 36 while front setting is 36 though I use 32. My Honda 929 & 953 of '00 & 03 have done well since.
I do not make grunt (short runs around town), but ride up in the mtn roads from 5 to 8+ hrs & no problems with my tyres other then normal wear caused by riding hard. Also on the rear it came stock with 190 & first replacement & every since has been 180 while stock on the front.
I have a '97 Yamaha YZF600R & run same size as stock though again drop the tyre pressure a bit-----more or less why I use on the two Honda bikes.
Unfortunately with a sportbike they do wear out at a faster rate then a cruiser or touring bike, but then entirely different makers to numbers/names used in said cases.
__________________
You may not post new threads
You may not post replies
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Forum Honda 600RR Forum Kawasaki Forum Yamaha R6 Forum Yamaha FZ-09 Forum
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Monster Forum Harley Forums Honda CBR250R Forum ZX10R Forum Star Raider Forum Yamaha Viking Forum
Suzuki GSXR Forum V-Rod Forums Honda Shadow Forum Kawasaki Motorcycle Forum Star Warrior Forum KTM Duke 390 Forum
SV650 Forum BMW S1000RR Forum Honda Fury Forum Kawasaki Versys Forum Drag Racing Forum Ducati 899 Panigale Forum
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes BMW NineT Forum
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum Suzuki GW250 Forum
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
Inactive Reminders By Mished.co.uk and FTP-Anime.com
